Hey, this is my first time posting on this forum. I have to admit, CCLeaner and Defraggler are very good programs. I've never found any program that has worked like this for me. But there is one problem. Everytime I defrag my computer, these files won't get defragged. Anyone know why? And can anyone suggest a solution to this problem of mine? Thanks
C:\System Volume Information\ belong to the System Restore feature of Windows, these files are not usually accessible to applications (unless you tweak folder permissions).
Turn off, then turn on the System Restore should empty these files automatically.
Richard S.
Thanks. But how do I do that? :S
Just to add to richard's post see here for info on avg log files
The pagefile.sys file is used when the RAM is full, then the system uses something like an extension of the ram. The defragmented of these files (pagefile.sys and hiberfil.sys), does not cause error, just can not be defragmented if these are in use.
Disable System Restore
XP
1. Right click My Computer and click Properties.
From the System Properties window, click the System Restore tab
Turn on Disable System Restore on all drives
Click apply and click OK.
Reboot.
Vista / Se7en
From the System Properties window, click the System Protection tab.
Select the drive for which you want to disable System Protection and click Configure.
Click Turn off system protection.
Reboot.
Disable hibernation
XP
1. Open Power Options in Control Panel
Select the Hibernate tab
Clear the checkbox for enabling hibernation
Reboot.
Vista / Se7en
1. Search cmd on Start Menu
Right-click on cmd and select Run As Administrator.
Click Continue when the UAC prompt appears.
Type powercfg -h off and then press ENTER.
Reboot.
note: Enable hibernation command: powercfg -h on
Disable Paging
XP / Vista / Se7en
1. Open System icon in the Control Panel
Select the Advanced tab
Under Performance, click Settings
Go to Advanced
Under Virtual Memory, click Change
Select No Paging File and then click Set
Click OK in all the menus
Reboot.
After defragmenting, re-enable paging, hibernation, and System Restore.
You can disable the three systems, and then restart, instead of every time you disable one. So to activate them.
