Defraggler installer trying to phone home
hi all
I’m curious why is the Defraggler installer triggering the Ping.exe and trying to phone home.
what is your version?
where was it downloaded from?
maybe checking for an update?
or maybe verifying license info?
it may be the bundled Google ware?
if downloaded from CNET, FileHippo etc, may be their download wrapper?
the latest one
The piriform website
Possible but unlikely the updater shouldn’t need to trigger ping.exe the only purpose of the ping.exe is to check for a connection so I’m not sure why the installer would be calling it
nope since its the free version
Maybe I do wish companies would stop bundling there apps with unwanted garbage if I wanted the tool bar I’d download it I guess at the end of the day its not a big issue just makes me a little suspicious when programs are doing things there not supposed to be because I found the Auslogics disk defrag app bundled with what my anti malware scanner identified as a Trojan horse the other day very disappointing to see reputable companies disseminating malware / PUPs (Potentially unwanted Programs)
Then buy software, bundling help keep good software free.
hi all
What is the answer to the original question?
