HI,
I am using Defraggler v2.7.0.346. [Windows XP Pro SP3, 2 GB RAM, 2 int HD: 160G + 60G. Various ext HD.]
I find that using the Explorer right-click to analyze and defragment a folder is not designed well.
If I right click a folder, I can choose to Check Fragmentation, or to Defragment.
If I choose Check Fragmentation, when it finishes and tells me the files fragmented, I no longer have a way to tell it to actually defragment. Only choice is to 'Close' or 'Open Defraggler'.
If I open Defraggler, I must go through the entire drive to analyze and choose what to do next.
But what I really want is to defragment the folder I just checked.
To do that, I must "Close" the information window. Now go back to folder in Explorer, and right-click the folder again and this time choose 'Defragment'.
This is NOT a good way to do it.
There should be a THIRD BUTTON choice to DEFRAGMENT this NOW.
(obviously, not in all caps... )
sample of the resulting Check Fragmentation (analyze) right-click choice attached (with my text notes, now redundant). The folder I am testing in this example is on the primary C HD, if that makes any difference.
Thank you.
It really is a nice and useful program for the most part.
