Defraggler does not defrag C:\System Volume Information\. I now have 8 files with this path, all of which are in the million size numbers with cryptic file names. Here is an example of one of them:
System Volume Information can't be defragged in Vista or Windows 7. There aren't any defraggers that I know of that can do it whether at boot or any other way. You can keep it under control by temporarily disabling System Restore (C:\System Volume Information are System Restore files). This will delete all the old restore points. Then enable System Restore again and create a new restore point. You may have to do this periodically.
Defraggler doesn't touch C:\System Volume Information because this folder (with exception to fat32) is protected by NTFS file security permissions by default.
I'm not sure if this works with Vista / Win7 but to gain access to SVI under XP you must login as Administrator, change the folder security permissions and give full access to Administrator (or to another user account).
It's not useless to delete C:\System Volume Information if you want to free up disk space. These files replicate like crazy and deleting them and starting fresh is the best way I know to keep them under control.
In Vista:
Open up a command prompt as Admin and type:
vssadmin list shadowstorage
This will show you how much disk space System Restore is using.
Then you can type the following to change the size:
Go to Control Panel -> System and Security -> System (or right click on Computer and select Properties). Click on System protection link in the tasks pane on the left.
In System Properties? System Protection tab, there will be a Protection Settings section. Select a drive and click on Configure button to change the parameters related to
System Protection and System Restore. The Max Usage value can be set to limit the maximum amount of disk space System Protection (System Restore) can use.
