I think the problem here is the fact that Defraggler can't find enough contiguous free space to defrag your big files.
Please do the following :
Move all your big files (i.e. > 1GB) on an external disk
Defrag free space allowing fragmentation
Do a normal defrag
Move your big files back
In Defraggler's Options, in the Defrag tab, check the "Move large files to end of drive" checkbox, and select 1024 as the limit.
Defrag again.
The last two steps are here to make sure those big, rarely used files (you don't watch all your movies everyday) will not slow your computer down since hard drives are faster at the beginning
Do a normal defrag
Defrag again.
Thanks.. I will go and try that.. Should I do all of the defragging while in safe mode?
Follow the above procedure BUT change it up alittle
1: disable hibernate and pagefile
reboot
2: run defraggler (thereby defragging only the main system files)
** On a side note, I'll usually shutdown everything running in my system tray, the idea is less running process's = faster defrag, as well as not having to worry about some files not getting defragmented due to being in use. (whether or not this is accurate I can't say for sure, it's just a theory of mine and I do it ...lol)
when defrag is complete enable hibernate and pagefile (your choice on which one you want directly after system files)
reboot
run defraggler and see the results
I did do this, while typing this out on my laptop, defraggler didn't appear to be any slower without the pagefile
results on 24.gb
initial fragmentation Before 49%
fragmentation after 0%
seems to work
**EDIT: I just did this on my laptop as well with the same results 0% when complete
I'd like to add (may or may not be relevant to my findings)
under defraggler/settings/options/defrag
I have "move large files to end of drive" and "move only selected files types" both checked with their default settings
