When I click Defrag it says it can build a file list....To be exact it says "Building file list failed "..
So whats the problem or how do I fixx it ?
Thanks
Thanks
Can you give more info.
What operating system are you using?
Is there anything 'different' about your setup?
Is this the first time you have used defraggler?
I am running Windows XP.
I have run the defragger sucessfully in the past but for some reason it will no work.
i have the same problem, but my defragger don?t work at check and defrag.
I have Vista Home (OEM)
and i used at a admin.
can someone help me???
Thanks!!!!!!
shows "Building file list failed "
i use XP
i did do these modifications:
link removed by moderator. Very old version of xp sp1 shown and involved a lot of registry editing
what went wrong?
