Hi,
I have Window Seven (integraled.) 32bit (clean install) on a pc AMD Athklon dual core 2,60Ghz, 2,00 gb ram, 320 hard drive, (half free)
And by the way, the PC goes weel and smootly.
Window defrag analysing tool was showing ? 16 % defragmentation. I never had something so high.
So I installed Pirifom Defraggler (so good reviews and i am a "ccleaner" fan)
After the deep defrag, I get to a amazing rate of 46 % fragmentation.
So frankly I was better before.
I redid a quick defrag, then checked disck, then a free space defrag, and again a deep defrag... but the rate positively remain high, now at 49%. (I will be in Guiness book or record soon! )
I know (from Vedan thread) that it is a problem with Window restore files, BUT I would like to keep these restore files, so be able to exclude them from the defrag analysis.
And hopefully get a positive defragmentation rate.
I would really like to know how to manage with that...
And maybe suggest that you give a correspondance table with window defrag rate and yours.
Thank you in advance for your time and help
Marie-Helene
Results scan on the attachement.
Marie-Helene
