I've used this product for about two weeks now and think its very handy. The only issue i'm seeing or just not figuring out is how to achieve this, but when I get the files i'm looking for I receive them in the original folders that i had them in to begin with. My issue is i want to bring that folder and all its content with it but it only brings the files within that folder. So i have to re-write all the folders and one by one re-insert the files into the original folder as i had prior to the deletion of the files. thank you for your assistance
I'm not quite sure what you're asking for, but check Restore Folder Structure in Options/Action in Advanced mode. If any folder name in the path is \?\ then you're out of luck, as the folder record has been overwritten.
