Hi, - I plugged in a couple of other internal HD's as secondary drives in my computer without problem to transfer data.
Now, with this one, which is a WD 1TB drive, it finds the drive in My Computer but doesn't show size, etc. and error message I get is: "S:\is not accessible. The disk structure is corrupted and unreadable." Disk management is showing RAW. I performed a deep scan and it took hours before it would even give an estimated time. After going to bed maybe 8 hours later, the progress was over 2000% and it was fluctuating every second between 1 day and 24 days. I read on the forum back around 2012 that Deep Scan is only for files that have been deleted, and that a deep scan will only show you files that have been deleted -- I'm fine with only seeing files that were never deleted -- was wondering if this is still the case? When I try to run quick scan it says : Failed to scan the following devices: S: Unable to read MFT"... I cancelled the deep scan and it did list and recover thousands of files after hitting cancel. It looks like there's a progress bar but I never saw anything highlighted....
I would totally buy the Pro version just not sure it will ever finish 100%....see screenshot.
