Deep clean
If I try and run a deep clean I press deep.clean it opens a deep clean page press the see results button it then opens a quick clean page so I cannot run a deep clean
If no one can help please give me an email to contact
Unfortunately we don’t have many CCleaner Android users here on the user forum.
You can raise a support ticket by using the form here:
DONT try to change the language o that webpage - it breaks if you do that and you will then have to close/reopen the browser to get it to work again.
You can also email then at: support@ccleaner.com
You should note that support are slow to answer these days and it can take a week or more for a registered customer to get a reply.
Further you should note that the automatic support queue works off email addresses.
So if the email you use when sending the form is not the one that you registered when purchasing CCleaner then you will not be seen as someone who has paid for support.
As an apparent ‘non-payer request’ your request will be non-priority and it may be a very long time (month or more) before the system even shows your request to a support person.
