Custom Folders disappearing issue
Hi Guys,
I'm new in this forum despite I am a "long-term Crap Cleaner" user :-)
It means it worked and works for me fine
Recently I decided to use Custom Folders which were cleaned as expected... and then I encountered this problem (see topic) when I have to restore Custom Folders List periodically.
Being a good boy I searched the forum before posting. And mainly found the answer.
The conclusion is: using another reg cleaner can inflict pain in this area.
So my question mainly has to be changed and now it sounds like this:
Are there any info describing how Ccleaners' developers are going to address this issue?
Thanks in advance
P.S.
what about old fashion ini or cnf? They even can be encrypted/passworded
Who says that the whole idea of the Registry is good?
I think that it is not. More over the way it is implemented it is actually - Crap. Oh, Yeah! Right! - that's why we have to clean Crap out of it... forgot :-)
Cheers
  1. Run CCleaner (make sure you have the newest version installed).
  2. Click Options, Advanced, and place a tick in the last selection which is:
    Save all settings to INI file
    This will completely remove all CCleaner setting from the registry and store them in:
    C:\Program Files\CCleaner\CCleaner.ini
Thanks for replying, Andavari.
Silly me!
What can I say, ... brainwashed by mightiness of stupid Registry...
How may times I was there in "Advanced"?
Our eyes see (ini), our mind just ignores it
Best regards
