I subscribe to Rhapsody and they recommend removing a temp file called radfile.rcf frequntly to get rid of junk that is accumulated by the main program. It is in the folder
C:\Program Files\Rhapsody\radfile.rcf on my machine. I added this path to the Custom box on CCleaner v 1.24.180 but it won't remove the file.
What am I doing wrong? ![<_<]()
Thank you
Have you ticked the box "Custom Files and Folders" in cleaner, windows, advanced(at the bottom)?
Thank you--that was the problem. I succeeded in adding the file and cleaning it.
I think after adding a custom cleaning that it should either automatically tick the box, or display a prompt that it has to be enabled since many people have been baffled by their custom cleaning not being performed. I guess what I just wrote should've actually been posted in the suggestions thread.
