Custom clean will not delete
Internet explorer temporary internet files
System Windows log files system Windows web cache CCleaner browser internet cache c cleaner browser internet history c cleaner browser cookies sea cleaner browser metrics temp file applications Microsoft OneDrive
How do I remove these. Total 32426 KB junk
Please dumb it down
Thanks
Is it actually saying that the cleanig is 'Skipped' ?
If Custom Clean is saying that something is being 'Skipped' then that is because it is still running.
In this case it sounds as if your browser is open.
Close the browser and it should then be cleaned instead of skipped.
For the other things, if it isn't saying 'Skipped' but instead you are seeing files coming back after cleaning then read this to see why that is and what you can do about it:
