This happened twice in the exact sequence: (Former Software Engineer & Systems Analyst) - I do financial analysis now
(1) I ran ccleaner with everything being cleaned (2) Immediately cut my system off (3) upon restarting it went to the error message how the hard drive was corrupt and it needed to be RESET.
The first time this happened i took both ssd’s out of the machine and put them in another machine to no avail, even external hdd cases to no avail. Weeks later I decided to put it back together and reset it - it worked and started up like nothing had happened.
The second time - is now. I am really PISSED. The first time it happened it 10 days before my custody court hearing and i had most everything backed up (except downloads which was a working directory before I moved it to a OneDrive directory.) This caused me great grief and problems in my custody hearing because of lack of some key documents.
CCLEANER IS UNRELIABLE AND WILL HARM YOUR SYSTEM. DO NOT USE IT. I WILL START A SEPARATE REVIEW WEBSITE SO WHEN ANYONE SEARCHES CCLEANER - IT WILL COME UP WITH MY STORY.
THEY DO NOT HAVE CUSTOMER SERVCIE. THEIR CUSTOMER SUPPORT IS A SERIES OF CIRCULAR LINKS FROM THE SAME PAGE TO THE SAME PAGE.
THESE PEOPLE NEED TO BE HELD ACCOUNTABLE.
