Crash on drive analysis
First of all, thanks for this GREAT tool. I've been using it for a while and I love it. :D But since today I have a problem.
OS: XP Professional Dutch version
Defraggler version: 1.06.118 (I updated to this version after the problems started, but the update didn't solve it.)
My SATA disk looks like this (sizes all rounded):
Primary partition 1: C:\ (Windows XP), NTFS, 20 GB
Primary partition 2: P:\ (Program Files), NTFS, 20 GB
Primary partition 3: X:\ (Flight Simulator X), NTFS, 40 GB
Extended partition 1: M:\ (Video), NTFS, 20 GB
Extended partition 2: Swap (Ubuntu swap), swap, 2 GB
Extended partition 3: /boot (Ubuntu boot), EXT3, 0.5 GB
Extended partition 4: / (Ubuntu root), EXT3, 20 GB
Extended partition 5: /home (Ubuntu homes), EXT3, 40 GB
Extended partition 6: F:\ (Tileproxy), NTFS, 40 GB
Extended partition 7: S:\ (Backup), NTFS, 100 GB
I start Defraggler, select drive X and click Analyze. Defraggler starts analyzing the disk until it reaches 100%, then it crashes and the standard Windows popup appears asking if I want to send a report bla bla. This has never happened before. Next to this tool I also use Jkdefrag, which defrags as a screensaver. That works stable as well, but you never know, maybe that tool f_cked up something... I don't know. I never use XP's own defragger.
Anyway, from the command line I started the debug version and a text file has been created called "Defraggler.exe.[1_6_118][2009-01-31_14-54].txt". These are the contents:
[2009-01-31] [14:54:15.831] 00dcc 0 Logger::HostLogger::LogApplicationInfo#617 P:\accesoires\Defraggler\Defraggler.exe[2009-01-31] [14:54:15.831] 00dcc 0 Logger::HostLogger::LogApplicationInfo#619 CmdLine: Defraggler.exe /debug[2009-01-31] [14:54:15.831] 00dcc 0 Logger::HostLogger::LogApplicationInfo#623 Version: 1_6_118[2009-01-31] [14:54:15.831] 00dcc 0 Logger::HostLogger::LogApplicationInfo#649 FileVersion: 1.6.0.118[2009-01-31] [14:54:15.831] 00dcc 0 Logger::HostLogger::LogApplicationInfo#650 ProductVersion: 1.6.0.118[2009-01-31] [14:54:15.831] 00dcc 0 Logger::HostLogger::LogApplicationInfo#651 Flags: 0x00000000, OS: 0x00000004, Type: 0x00000002, Subtype: 0x00000000[2009-01-31] [14:54:15.831] 00dcc 0 Logger::HostLogger::LogApplicationInfo#652 Flags description: Release[2009-01-31] [14:54:15.831] 00dcc 0 Logger::HostLogger::LogSystemInfo#670 Computer name: pjurkje[2009-01-31] [14:54:15.831] 00dcc 0 Logger::HostLogger::LogSystemInfo#677 User name: Gerben Wijnja[2009-01-31] [14:54:15.831] 00dcc 0 Logger::HostLogger::LogSystemInfo#685 OEM ID: 0[2009-01-31] [14:54:15.831] 00dcc 0 Logger::HostLogger::LogSystemInfo#686 Number of processors: 1[2009-01-31] [14:54:15.831] 00dcc 0 Logger::HostLogger::LogSystemInfo#687 Page size: 4096[2009-01-31] [14:54:15.831] 00dcc 0 Logger::HostLogger::LogSystemInfo#688 Processor type: 586[2009-01-31] [14:54:15.831] 00dcc 0 Logger::HostLogger::LogSystemInfo#689 Minimum application address: 10000[2009-01-31] [14:54:15.831] 00dcc 0 Logger::HostLogger::LogSystemInfo#690 Maximum application address: 7ffeffff[2009-01-31] [14:54:15.831] 00dcc 0 Logger::HostLogger::LogSystemInfo#691 Active processor mask: 1[2009-01-31] [14:54:15.831] 00dcc 0 Logger::HostLogger::LogSystemInfo#694 Clean boot: 0[2009-01-31] [14:54:15.831] 00dcc 0 Logger::HostLogger::LogSystemInfo#695 Monitors: 1, Display: 1680x1050, Virtual: 0x0 1680x1050[2009-01-31] [14:54:15.831] 00dcc 0 Logger::HostLogger::LogSystemInfo#705 Major: 0x00000005, Minor: 0x00000001, Build: 2600, PlatformId: 0x00000002[2009-01-31] [14:54:15.831] 00dcc 0 Logger::HostLogger::LogSystemInfo#706 SPMajor: 0x0003, SPMinor: 0x0000, CSDVersion: "Service Pack 3"[2009-01-31] [14:54:15.831] 00dcc 0 Logger::HostLogger::LogSystemInfo#707 SuiteMask: 0x00000100, ProductType: 0x00000001[2009-01-31] [14:54:15.831] 00dcc 0 Logger::HostLogger::LogSystemInfo#719 Memory: Load: 43, Physical: 1219923968/2146942976, PageFile: 3370598400/4133285888, Virtual: 2113961984/2147352576, Extended 0[2009-01-31] [14:54:15.831] 00dcc 1 wWinMain#135 /debug[2009-01-31] [14:54:15.847] 00dcc 1 CDriveListForm::CDriveListForm#37 GetSystemWindowsDirectory returned "C:\WINDOWS" (system volume is C:).[2009-01-31] [14:54:15.847] 00dcc 1 CMainFrame::CMainFrame#176 Entering CMainFrame::CMainFrame[2009-01-31] [14:54:15.847] 00dcc 1 CMainFrame::CMainFrame#176 Leaving CMainFrame::CMainFrame[2009-01-31] [14:54:15.847] 00dcc 1 CMainFrame::OnCreate#462 Entering CMainFrame::OnCreate[2009-01-31] [14:54:15.847] 00dcc 1 CMainFrame::CreateChildWindows#317 Creating driveListForm_.[2009-01-31] [14:54:15.847] 00dcc 1 CMainFrame::CreateChildWindows#319 Creating driveMapForm_.[2009-01-31] [14:54:15.847] 00dcc 1 CMainFrame::CreateChildWindows#321 Creating fileListForm_.[2009-01-31] [14:54:15.894] 00dcc 1 CMainFrame::PrepareLayout#352 Updating layout.[2009-01-31] [14:54:15.894] 00dcc 1 CCheckForUpdates::CheckForUpdates#36 Checking for updates[2009-01-31] [14:54:15.894] 00dcc 1 CCheckForUpdates::CheckForUpdates#52 Update check is not needed[2009-01-31] [14:54:15.894] 00dcc 1 CCheckForUpdates::CheckForUpdates#57 Forcing update check[2009-01-31] [14:54:15.894] 00fd4 1 CCheckForUpdates::CheckThread#68 Update check thread started[2009-01-31] [14:54:15.894] 00dcc 1 CMainFrame::OnCreate#496 Registering object for message filtering.[2009-01-31] [14:54:15.894] 00dcc 1 CMainFrame::Initialize#375 Initializing VolumeManager.[2009-01-31] [14:54:15.894] 00dcc 1 CVolumeManagerBase::CVolumeManagerBase#10 Entering CVolumeManagerBase::CVolumeManagerBase[2009-01-31] [14:54:15.894] 00dcc 1 CVolumeManagerBase::CVolumeManagerBase#10 Leaving CVolumeManagerBase::CVolumeManagerBase[2009-01-31] [14:54:15.956] 00dcc 1 CVolumeManager::CVolumeManager#10 Entering CVolumeManager::CVolumeManager[2009-01-31] [14:54:15.956] 00dcc 1 CVolumeManager::CVolumeManager#10 Leaving CVolumeManager::CVolumeManager[2009-01-31] [14:54:15.956] 00dcc 1 CVolumeManager::Initialize#19 Entering CVolumeManager::Initialize[2009-01-31] [14:54:15.956] 00dcc 1 CVolumeManagerBase::Initialize#18 Entering CVolumeManagerBase::Initialize[2009-01-31] [14:54:15.956] 00dcc 1 CVolumeManagerBase::Initialize#28 Enabling SE_BACKUP_NAME privilege succeeded.[2009-01-31] [14:54:15.956] 00dcc 1 CVolumeManagerBase::Initialize#34 Enabling SE_RESTORE_NAME privilege succeeded.[2009-01-31] [14:54:15.956] 00dcc 1 CVolumeManagerBase::Initialize#18 Leaving CVolumeManagerBase::Initialize[2009-01-31] [14:54:15.956] 00dcc 1 CVolumeManager::Initialize#19 Leaving CVolumeManager::Initialize[2009-01-31] [14:54:15.956] 00dcc 1 CMainFrame::Initialize#380 Initializing VolumeNavigator.[2009-01-31] [14:54:15.956] 00a14 1 CVolumeManagerBase::RebuildVolumesMap#103 Logical drives mask: 0x03d4b02e, arrival mask: 0xffffffff, removal mask: 0x00000000.[2009-01-31] [14:54:15.956] 00a14 1 CVolumeManagerBase::UpdateVolume#262 Start update for volume B:.[2009-01-31] [14:54:15.956] 00a14 1 CVolumeManagerBase::GetBasicVolumeInfo#217 Unsupported drive type 4 for volume B:[2009-01-31] [14:54:15.956] 00a14 1 CVolumeManagerBase::UpdateVolume#298 Finish update for bvi B:.[2009-01-31] [14:54:15.956] 00a14 1 CVolumeManagerBase::UpdateVolume#262 Start update for volume C:.[2009-01-31] [14:54:15.956] 00dcc 1 CDriveMap::CDriveMap#17 Entering CDriveMap::CDriveMap[2009-01-31] [14:54:15.956] 00dcc 1 CDriveMap::CDriveMap#17 Leaving CDriveMap::CDriveMap[2009-01-31] [14:54:15.956] 00dcc 1 CVolumeNavigator::CVolumeNavigator#9 Entering CVolumeNavigator::CVolumeNavigator[2009-01-31] [14:54:15.956] 00dcc 1 CVolumeNavigator::CVolumeNavigator#9 Leaving CVolumeNavigator::CVolumeNavigator[2009-01-31] [14:54:15.956] 00dcc 1 CVolumeNavigator::Initialize#23 Entering CVolumeNavigator::Initialize[2009-01-31] [14:54:15.956] 00dcc 1 CVolumeNavigator::Initialize#23 Leaving CVolumeNavigator::Initialize[2009-01-31] [14:54:15.956] 00dcc 1 CDriveListForm::OnVolumesMapChange#421 Select first volume on list.[2009-01-31] [14:54:15.956] 00dcc 1 CFilesListViewImpl::DoSort#264 Sorting 0 elements took 0.0000 seconds[2009-01-31] [14:54:16.003] 00dcc 1 CMainFrame::OnCreate#462 Leaving CMainFrame::OnCreate[2009-01-31] [14:54:16.019] 00a14 1 CVolume::CVolume#31 CVolume object created for volume C:.[2009-01-31] [14:54:16.019] 00a14 1 CVolumeManagerBase::UpdateVolume#277 Volume: C:, size: 21476173824, free: 6072385536, fs: NTFS, name: "Windows XP".[2009-01-31] [14:54:16.019] 00a14 1 CVolumeManager::OnVolumeAdded#56 Entering CVolumeManager::OnVolumeAdded[2009-01-31] [14:54:16.019] 00a14 1 CVolumeManager::ChangeNotificationOwner::ChangeNotificationOwner#47 Registered notification for "C:\", handle: 0x0000044c[2009-01-31] [14:54:16.035] 00a14 1 CVolume::Initialize#49 Intialization for volume C: started.[2009-01-31] [14:54:16.066] 00a14 1 CVolume::Initialize#82 Volume C: open, handle 0x00000430.[2009-01-31] [14:54:16.066] 00a14 1 IsFatVolume#16 File system type for volume 0x00000430 is NTFS.[2009-01-31] [14:54:16.066] 00a14 1 CVolume::Initialize#94 GetClustersCount for volume C: returned 5243206 clusters.[2009-01-31] [14:54:16.081] 00a14 1 CVolume::ReloadMap#247 00 00 00 00 00 00 00 00 46 01 50 00 00 00 00 00 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff [2009-01-31] [14:54:16.081] 00a14 1 CVolume::ReloadMap#260 MftZone: <3310880, 3944448).[2009-01-31] [14:54:16.081] 00a14 1 CVolume::Initialize#120 Raise VolumeMapChangedSignal for volume C:.[2009-01-31] [14:54:16.081] 00a14 1 CVolume::Initialize#124 Intialization for volume C: finished.[2009-01-31] [14:54:16.081] 00a14 1 CVolumeManager::OnVolumeAdded#56 Leaving CVolumeManager::OnVolumeAdded[2009-01-31] [14:54:16.081] 00dcc 1 CVolumeNavigator::ConnectToVolumeSignals#151 Connecting to volume C: signals.[2009-01-31] [14:54:16.097] 00dcc 1 CDriveListForm::OnVolumesMapChange#412 Select default volume C.[2009-01-31] [14:54:16.097] 00dcc 1 CVolumeNavigator::SelectVolume#331 New volume selected: C:.[2009-01-31] [14:54:16.097] 00dcc 1 CFilesListViewImpl::DoSort#264 Sorting 0 elements took 0.0000 seconds[2009-01-31] [14:54:16.097] 00dcc 1 CDiskIconCtrl::OnCurrentVolumeChanged#131 LoadLibraryEx("C:\AUTORUN\xp.ico") failed (hr=0x800700c1)[2009-01-31] [14:54:16.128] 00a14 1 CVolumeManagerBase::UpdateVolume#298 Finish update for bvi C:.[2009-01-31] [14:54:16.128] 00a14 1 CVolumeManagerBase::UpdateVolume#262 Start update for volume D:.[2009-01-31] [14:54:16.128] 00a14 1 CVolumeManagerBase::GetBasicVolumeInfo#217 Unsupported drive type 5 for volume D:[2009-01-31] [14:54:16.128] 00a14 1 CVolumeManagerBase::UpdateVolume#298 Finish update for bvi D:.[2009-01-31] [14:54:16.128] 00a14 1 CVolumeManagerBase::UpdateVolume#262 Start update for volume F:.[2009-01-31] [14:54:16.128] 00a14 1 CVolume::CVolume#31 CVolume object created for volume F:.[2009-01-31] [14:54:16.128] 00a14 1 CVolumeManagerBase::UpdateVolume#277 Volume: F:, size: 42952379904, free: 15015632896, fs: NTFS, name: "TileProxy".[2009-01-31] [14:54:16.128] 00a14 1 CVolumeManager::OnVolumeAdded#56 Entering CVolumeManager::OnVolumeAdded[2009-01-31] [14:54:16.128] 00a14 1 CVolumeManager::ChangeNotificationOwner::ChangeNotificationOwner#47 Registered notification for "F:\", handle: 0x0000042c[2009-01-31] [14:54:16.128] 00a14 1 CVolume::Initialize#49 Intialization for volume F: started.[2009-01-31] [14:54:16.128] 00a14 1 CVolume::Initialize#82 Volume F: open, handle 0x00000428.[2009-01-31] [14:54:16.128] 00a14 1 IsFatVolume#16 File system type for volume 0x00000428 is NTFS.[2009-01-31] [14:54:16.128] 00a14 1 CVolume::Initialize#94 GetClustersCount for volume F: returned 10486420 clusters.[2009-01-31] [14:54:16.175] 00a14 1 CVolume::ReloadMap#247 00 00 00 00 00 00 00 00 94 02 a0 00 00 00 00 00 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff [2009-01-31] [14:54:16.175] 00a14 1 CVolume::ReloadMap#260 MftZone: <3513888, 3515200).[2009-01-31] [14:54:16.175] 00a14 1 CVolume::Initialize#120 Raise VolumeMapChangedSignal for volume F:.[2009-01-31] [14:54:16.175] 00a14 1 CVolume::Initialize#124 Intialization for volume F: finished.[2009-01-31] [14:54:16.175] 00a14 1 CVolumeManager::OnVolumeAdded#56 Leaving CVolumeManager::OnVolumeAdded[2009-01-31] [14:54:16.175] 00dcc 1 CVolumeNavigator::ConnectToVolumeSignals#151 Connecting to volume F: signals.[2009-01-31] [14:54:16.191] 00a14 1 CVolumeManagerBase::UpdateVolume#298 Finish update for bvi F:.[2009-01-31] [14:54:16.191] 00a14 1 CVolumeManagerBase::UpdateVolume#262 Start update for volume M:.[2009-01-31] [14:54:16.191] 00a14 1 CVolume::CVolume#31 CVolume object created for volume M:.[2009-01-31] [14:54:16.191] 00a14 1 CVolumeManagerBase::UpdateVolume#277 Volume: M:, size: 21476173824, free: 875651072, fs: NTFS, name: "VIDEO".[2009-01-31] [14:54:16.191] 00a14 1 CVolumeManager::OnVolumeAdded#56 Entering CVolumeManager::OnVolumeAdded[2009-01-31] [14:54:16.191] 00a14 1 CVolumeManager::ChangeNotificationOwner::ChangeNotificationOwner#47 Registered notification for "M:\", handle: 0x00000424[2009-01-31] [14:54:16.191] 00a14 1 CVolume::Initialize#49 Intialization for volume M: started.[2009-01-31] [14:54:16.191] 00a14 1 CVolume::Initialize#82 Volume M: open, handle 0x00000420.[2009-01-31] [14:54:16.191] 00a14 1 IsFatVolume#16 File system type for volume 0x00000420 is NTFS.[2009-01-31] [14:54:16.191] 00a14 1 CVolume::Initialize#94 GetClustersCount for volume M: returned 5243206 clusters.[2009-01-31] [14:54:16.206] 00fd4 1 CCheckForUpdates::CheckThread#131 CheckForUpdate succeeded. (isUpdateAvailable: 0, newVersion: "1.06.118")[2009-01-31] [14:54:16.222] 00a14 1 CVolume::ReloadMap#247 00 00 00 00 00 00 00 00 46 01 50 00 00 00 00 00 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff 7f 00 00 00 00 00 00 00 00 [2009-01-31] [14:54:16.222] 00a14 1 CVolume::ReloadMap#260 MftZone: <1748992, 1804480).[2009-01-31] [14:54:16.222] 00a14 1 CVolume::Initialize#120 Raise VolumeMapChangedSignal for volume M:.[2009-01-31] [14:54:16.222] 00a14 1 CVolume::Initialize#124 Intialization for volume M: finished.[2009-01-31] [14:54:16.222] 00a14 1 CVolumeManager::OnVolumeAdded#56 Leaving CVolumeManager::OnVolumeAdded[2009-01-31] [14:54:16.222] 00dcc 1 CVolumeNavigator::ConnectToVolumeSignals#151 Connecting to volume M: signals.[2009-01-31] [14:54:16.222] 00a14 1 CVolumeManagerBase::UpdateVolume#298 Finish update for bvi M:.[2009-01-31] [14:54:16.222] 00a14 1 CVolumeManagerBase::UpdateVolume#262 Start update for volume N:.[2009-01-31] [14:54:16.222] 00a14 1 CVolumeManagerBase::GetBasicVolumeInfo#217 Unsupported drive type 4 for volume N:[2009-01-31] [14:54:16.222] 00a14 1 CVolumeManagerBase::UpdateVolume#298 Finish update for bvi N:.[2009-01-31] [14:54:16.222] 00a14 1 CVolumeManagerBase::UpdateVolume#262 Start update for volume P:.[2009-01-31] [14:54:16.238] 00a14 1 CVolume::CVolume#31 CVolume object created for volume P:.[2009-01-31] [14:54:16.238] 00a14 1 CVolumeManagerBase::UpdateVolume#277 Volume: P:, size: 21476206080, free: 13947719680, fs: NTFS, name: "Program Files".[2009-01-31] [14:54:16.238] 00a14 1 CVolumeManager::OnVolumeAdded#56 Entering CVolumeManager::OnVolumeAdded[2009-01-31] [14:54:16.238] 00a14 1 CVolumeManager::ChangeNotificationOwner::ChangeNotificationOwner#47 Registered notification for "P:\", handle: 0x0000040c[2009-01-31] [14:54:16.238] 00a14 1 CVolume::Initialize#49 Intialization for volume P: started.[2009-01-31] [14:54:16.238] 00a14 1 CVolume::Initialize#82 Volume P: open, handle 0x0000050c.[2009-01-31] [14:54:16.238] 00a14 1 IsFatVolume#16 File system type for volume 0x0000050c is NTFS.[2009-01-31] [14:54:16.238] 00a14 1 CVolume::Initialize#94 GetClustersCount for volume P: returned 5243214 clusters.[2009-01-31] [14:54:16.269] 00a14 1 CVolume::ReloadMap#247 00 00 00 00 00 00 00 00 4e 01 50 00 00 00 00 00 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff [2009-01-31] [14:54:16.269] 00a14 1 CVolume::ReloadMap#260 MftZone: <1767488, 1982944).[2009-01-31] [14:54:16.269] 00a14 1 CVolume::Initialize#120 Raise VolumeMapChangedSignal for volume P:.[2009-01-31] [14:54:16.269] 00a14 1 CVolume::Initialize#124 Intialization for volume P: finished.[2009-01-31] [14:54:16.269] 00a14 1 CVolumeManager::OnVolumeAdded#56 Leaving CVolumeManager::OnVolumeAdded[2009-01-31] [14:54:16.269] 00dcc 1 CVolumeNavigator::ConnectToVolumeSignals#151 Connecting to volume P: signals.[2009-01-31] [14:54:16.269] 00a14 1 CVolumeManagerBase::UpdateVolume#298 Finish update for bvi P:.[2009-01-31] [14:54:16.269] 00a14 1 CVolumeManagerBase::UpdateVolume#262 Start update for volume S:.[2009-01-31] [14:54:16.285] 00a14 1 CVolume::CVolume#31 CVolume object created for volume S:.[2009-01-31] [14:54:16.285] 00a14 1 CVolumeManagerBase::UpdateVolume#277 Volume: S:, size: 105735942144, free: 37436862464, fs: NTFS, name: "BACKUP".[2009-01-31] [14:54:16.285] 00a14 1 CVolumeManager::OnVolumeAdded#56 Entering CVolumeManager::OnVolumeAdded[2009-01-31] [14:54:16.285] 00a14 1 CVolumeManager::ChangeNotificationOwner::ChangeNotificationOwner#47 Registered notification for "S:\", handle: 0x00000410[2009-01-31] [14:54:16.300] 00a14 1 CVolume::Initialize#49 Intialization for volume S: started.[2009-01-31] [14:54:16.316] 00a14 1 CVolume::Initialize#82 Volume S: open, handle 0x00000408.[2009-01-31] [14:54:16.316] 00a14 1 IsFatVolume#16 File system type for volume 0x00000408 is NTFS.[2009-01-31] [14:54:16.316] 00a14 1 CVolume::Initialize#94 GetClustersCount for volume S: returned 25814438 clusters.[2009-01-31] [14:54:16.425] 00a14 1 CVolume::ReloadMap#247 00 00 00 00 00 00 00 00 a6 e5 89 01 00 00 00 00 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff [2009-01-31] [14:54:16.425] 00a14 1 CVolume::ReloadMap#260 MftZone: <8614272, 8847360).[2009-01-31] [14:54:16.425] 00a14 1 CVolume::Initialize#120 Raise VolumeMapChangedSignal for volume S:.[2009-01-31] [14:54:16.425] 00a14 1 CVolume::Initialize#124 Intialization for volume S: finished.[2009-01-31] [14:54:16.425] 00a14 1 CVolumeManager::OnVolumeAdded#56 Leaving CVolumeManager::OnVolumeAdded[2009-01-31] [14:54:16.425] 00dcc 1 CVolumeNavigator::ConnectToVolumeSignals#151 Connecting to volume S: signals.[2009-01-31] [14:54:16.441] 00a14 1 CVolumeManagerBase::UpdateVolume#298 Finish update for bvi S:.[2009-01-31] [14:54:16.441] 00a14 1 CVolumeManagerBase::UpdateVolume#262 Start update for volume U:.[2009-01-31] [14:54:16.441] 00a14 1 CVolume::CVolume#31 CVolume object created for volume U:.[2009-01-31] [14:54:16.441] 00a14 1 CVolumeManagerBase::UpdateVolume#277 Volume: U:, size: 263176704, free: 137764864, fs: Ext2, name: "".[2009-01-31] [14:54:16.441] 00a14 1 CVolumeManager::OnVolumeAdded#56 Entering CVolumeManager::OnVolumeAdded[2009-01-31] [14:54:16.441] 00a14 1 CVolumeManager::ChangeNotificationOwner::ChangeNotificationOwner#47 Registered notification for "U:\", handle: 0x00000404[2009-01-31] [14:54:16.441] 00a14 1 CVolume::Initialize#49 Intialization for volume U: started.[2009-01-31] [14:54:16.441] 00a14 1 CVolume::Initialize#82 Volume U: open, handle 0x00000400.[2009-01-31] [14:54:16.441] 00a14 1 IsFatVolume#20 FSCTL_FILESYSTEM_GET_STATISTICS for handle 0x00000400 failed with error code 1[2009-01-31] [14:54:16.441] 00a14 1 GetClustersCount#52 FSCTL_GET_VOLUME_BITMAP for handle 0x00000400 failed with error code 1[2009-01-31] [14:54:16.441] 00a14 1 CVolume::Initialize#89 GetClustersCount for volume U: failed with error code 0x80070001.[2009-01-31] [14:54:16.441] 00a14 1 CVolumeManager::OnVolumeAdded#56 Leaving CVolumeManager::OnVolumeAdded[2009-01-31] [14:54:16.441] 00dcc 1 CVolumeNavigator::ConnectToVolumeSignals#151 Connecting to volume U: signals.[2009-01-31] [14:54:16.441] 00a14 1 CVolumeManagerBase::UpdateVolume#298 Finish update for bvi U:.[2009-01-31] [14:54:16.441] 00a14 1 CVolumeManagerBase::UpdateVolume#262 Start update for volume W:.[2009-01-31] [14:54:16.441] 00a14 1 CVolumeManagerBase::GetBasicVolumeInfo#217 Unsupported drive type 4 for volume W:[2009-01-31] [14:54:16.441] 00a14 1 CVolumeManagerBase::UpdateVolume#298 Finish update for bvi W:.[2009-01-31] [14:54:16.441] 00a14 1 CVolumeManagerBase::UpdateVolume#262 Start update for volume X:.[2009-01-31] [14:54:16.441] 00a14 1 CVolume::CVolume#31 CVolume object created for volume X:.[2009-01-31] [14:54:16.441] 00a14 1 CVolumeManagerBase::UpdateVolume#277 Volume: X:, size: 42952412160, free: 5386027008, fs: NTFS, name: "FSX".[2009-01-31] [14:54:16.441] 00a14 1 CVolumeManager::OnVolumeAdded#56 Entering CVolumeManager::OnVolumeAdded[2009-01-31] [14:54:16.441] 00a14 1 CVolumeManager::ChangeNotificationOwner::ChangeNotificationOwner#47 Registered notification for "X:\", handle: 0x000003fc[2009-01-31] [14:54:16.456] 00a14 1 CVolume::Initialize#49 Intialization for volume X: started.[2009-01-31] [14:54:16.456] 00a14 1 CVolume::Initialize#82 Volume X: open, handle 0x000003f8.[2009-01-31] [14:54:16.456] 00a14 1 IsFatVolume#16 File system type for volume 0x000003f8 is NTFS.[2009-01-31] [14:54:16.456] 00a14 1 CVolume::Initialize#94 GetClustersCount for volume X: returned 10486428 clusters.[2009-01-31] [14:54:16.488] 00a14 1 CVolume::ReloadMap#247 00 00 00 00 00 00 00 00 9c 02 a0 00 00 00 00 00 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff [2009-01-31] [14:54:16.488] 00a14 1 CVolume::ReloadMap#260 MftZone: <797088, 852928).[2009-01-31] [14:54:16.488] 00a14 1 CVolume::Initialize#120 Raise VolumeMapChangedSignal for volume X:.[2009-01-31] [14:54:16.488] 00a14 1 CVolume::Initialize#124 Intialization for volume X: finished.[2009-01-31] [14:54:16.488] 00a14 1 CVolumeManager::OnVolumeAdded#56 Leaving CVolumeManager::OnVolumeAdded[2009-01-31] [14:54:16.488] 00dcc 1 CVolumeNavigator::ConnectToVolumeSignals#151 Connecting to volume X: signals.[2009-01-31] [14:54:16.519] 00a14 1 CVolumeManagerBase::UpdateVolume#298 Finish update for bvi X:.[2009-01-31] [14:54:16.519] 00a14 1 CVolumeManagerBase::UpdateVolume#262 Start update for volume Y:.[2009-01-31] [14:54:16.519] 00a14 1 CVolume::CVolume#31 CVolume object created for volume Y:.[2009-01-31] [14:54:16.519] 00a14 1 CVolumeManagerBase::UpdateVolume#277 Volume: Y:, size: 249275335680, free: 138111946752, fs: Ext2, name: "".[2009-01-31] [14:54:16.519] 00a14 1 CVolumeManager::OnVolumeAdded#56 Entering CVolumeManager::OnVolumeAdded[2009-01-31] [14:54:16.519] 00a14 1 CVolumeManager::ChangeNotificationOwner::ChangeNotificationOwner#47 Registered notification for "Y:\", handle: 0x000003f4[2009-01-31] [14:54:16.519] 00a14 1 CVolume::Initialize#49 Intialization for volume Y: started.[2009-01-31] [14:54:16.519] 00a14 1 CVolume::Initialize#82 Volume Y: open, handle 0x000003f0.[2009-01-31] [14:54:16.519] 00a14 1 IsFatVolume#20 FSCTL_FILESYSTEM_GET_STATISTICS for handle 0x000003f0 failed with error code 1[2009-01-31] [14:54:16.519] 00a14 1 GetClustersCount#52 FSCTL_GET_VOLUME_BITMAP for handle 0x000003f0 failed with error code 1[2009-01-31] [14:54:16.519] 00a14 1 CVolume::Initialize#89 GetClustersCount for volume Y: failed with error code 0x80070001.[2009-01-31] [14:54:16.519] 00a14 1 CVolumeManager::OnVolumeAdded#56 Leaving CVolumeManager::OnVolumeAdded[2009-01-31] [14:54:16.519] 00dcc 1 CVolumeNavigator::ConnectToVolumeSignals#151 Connecting to volume Y: signals.[2009-01-31] [14:54:16.519] 00a14 1 CVolumeManagerBase::UpdateVolume#298 Finish update for bvi Y:.[2009-01-31] [14:54:16.519] 00a14 1 CVolumeManagerBase::UpdateVolume#262 Start update for volume Z:.[2009-01-31] [14:54:16.519] 00a14 1 CVolumeManagerBase::GetBasicVolumeInfo#217 Unsupported drive type 4 for volume Z:[2009-01-31] [14:54:16.519] 00a14 1 CVolumeManagerBase::UpdateVolume#298 Finish update for bvi Z:.[2009-01-31] [14:54:16.535] 00cb4 1 CVolume::UpdateDriveMap#340 Map generated in 0.42336 seconds.[2009-01-31] [14:54:20.488] 00dcc 1 CVolumeNavigator::SelectVolume#331 New volume selected: X:.[2009-01-31] [14:54:20.503] 00dcc 1 CFilesListViewImpl::DoSort#264 Sorting 0 elements took 0.0000 seconds[2009-01-31] [14:54:20.503] 00dcc 1 FindResourceNameFromOrdinal::FindResourceIdFromOrdinal::BeginSearching#73 EnumResourceNames failed (hr=0x00000000)[2009-01-31] [14:54:20.550] 00cb4 1 CVolume::UpdateDriveMap#340 Map generated in 0.04774 seconds.[2009-01-31] [14:54:21.878] 00d10 1 CVolumeOperationScheduler::ExecuteQueuedMethods#201 ---------------- Long task started ----------------[2009-01-31] [14:54:21.878] 00d10 1 CAnalysis::AnalyzeVolume#17 Entering CAnalysis::AnalyzeVolume[2009-01-31] [14:54:21.878] 00d10 1 CAnalysis::AnalyzeVolume#25 Analysis of volume X: started[2009-01-31] [14:54:21.878] 00d10 1 Wow64FsRedirectorDisabler::Acquire#38 Wow64DisableWow64FsRedirection skipped.[2009-01-31] [14:54:21.878] 00d10 1 CAnalysis::AnalyzeVolume#60 Volume X: flushed.[2009-01-31] [14:54:21.925] 00d10 1 CVolume::ReloadMap#247 00 00 00 00 00 00 00 00 9c 02 a0 00 00 00 00 00 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff [2009-01-31] [14:54:21.925] 00d10 1 CVolume::ReloadMap#260 MftZone: <797088, 852928).[2009-01-31] [14:54:21.925] 00d10 1 CAnalysis::AnalyzeVolume#76 Initialization finished in 0.048 seconds.[2009-01-31] [14:54:21.925] 00dcc 1 CFilesListViewImpl::DoSort#264 Sorting 0 elements took 0.0000 seconds[2009-01-31] [14:54:21.956] 00d10 1 CNtfs::ReadMftVcn#167 Using MFT record data runs for volume X.[2009-01-31] [14:54:21.988] 00cb4 1 CVolume::UpdateDriveMap#340 Map generated in 0.13317 seconds.[2009-01-31] [14:54:22.175] 00d10 1 CAnalysis::AnalyzeNtfsVolume#170 ReadFileRecords for 0/16384 took 0.213 seconds.[2009-01-31] [14:54:22.269] 00d10 1 CAnalysis::AnalyzeNtfsVolume#286 Processing 16384 items took 0.085 seconds.[2009-01-31] [14:54:22.269] 00d10 1 CNtfs::ReadMftVcn#167 Using MFT record data runs for volume X.[2009-01-31] [14:54:22.488] 00d10 1 CAnalysis::AnalyzeNtfsVolume#170 ReadFileRecords for 16385/16384 took 0.223 seconds.[2009-01-31] [14:54:22.488] 00d10 1 CAnalysis::GetFileFragmentsAndSize#342 ERROR: failed to retrieve file size! (err.code() is 2 for file "?M")[2009-01-31] [14:54:22.488] 00d10 1 CAnalysis::GetFileFragmentsAndSize#342 ERROR: failed to retrieve file size! (err.code() is 2 for file "?M")[2009-01-31] [14:54:22.488] 00d10 1 CAnalysis::GetFileFragmentsAndSize#342 ERROR: failed to retrieve file size! (err.code() is 2 for file "?M")[2009-01-31] [14:54:22.488] 00d10 1 CAnalysis::GetFileFragmentsAndSize#342 ERROR: failed to retrieve file size! (err.code() is 2 for file "?M")[2009-01-31] [14:54:22.660] 00d10 1 CAnalysis::AnalyzeNtfsVolume#224 Mft record for file 23436 doesn't contain file name attribute.[2009-01-31] [14:54:22.847] 00d10 1 CAnalysis::AnalyzeNtfsVolume#286 Processing 16384 items took 0.369 seconds.[2009-01-31] [14:54:22.847] 00d10 1 CNtfs::ReadMftVcn#167 Using MFT record data runs for volume X.[2009-01-31] [14:54:22.878] 00cb4 1 CVolume::UpdateDriveMap#340 Map generated in 0.08016 seconds.[2009-01-31] [14:54:22.988] 00d10 1 CAnalysis::AnalyzeNtfsVolume#170 ReadFileRecords for 32769/9856 took 0.131 seconds.[2009-01-31] [14:54:23.081] 00d10 1 CAnalysis::AnalyzeNtfsVolume#224 Mft record for file 42596 doesn't contain file name attribute.[2009-01-31] [14:54:23.722] 00cb4 1 CVolume::UpdateDriveMap#340 Map generated in 0.05142 seconds.
Hope it helps. Thanks in advance!
Regards,
Gerben
