CPU Temp no longer displayed on V.1.32.803
The CPU Temp was one of the more used pieces of information for me and it seems to no longer be available on V1.32.803 running Windows 11 PRO with all the updates.
It used to show on the CPU line right after it says Intel processor. Clicking on Options gives expanded data about the CPU but still no temperature.
The motherboard section shows the motherboard temperature and that is a good feature.
It would also be nice to toggle between Celsius and Fahrenheit when showing temperatures.
Thanks,
Chuck F.
