When I first ran Speccy I saw that my CPU temps were near and sometimes even above max, so I was very concerned. I installed CoreTemp and it reported the temps well within the safe range.
Speedfan shows the same temps as Speccy. It seems to be something about that particular CPU because Everest gave me a message saying it isn't supported and only shows the HDD temp. I believe CoreTemp is correct because if Speccy & Speedfan were right my CPU would be toast.
