CPU Multi Core Detection Bug?
Hello,
I have a Dell 9000 with I7-975EE CPU [using Windows 7 Pro 64bit].
Speccy is reporting 2 cores with 4 threads [HT].
I checked BIOS and it says to use ALL cores, so it should report 4 cores and either 4 or 8 threads.
I'm not sure if HT is enabled and can not find out how to tell, Dell's BIOS does not have an option for HT. Device manager is reporting 8 CPU's so I think that means HT is enabled [but I'm not sure].
In any case I think [hope] there is a bug in Speccy [1.0.1.132] not detecting all 4 Cores.
BTW: Great Product.
Thanks,
- Dave
