When cleaning cookies, ccleaner stops after reaching 4% and stays there, no movement at all, most likely im doing something wrong, but not sure what
Can you give a little bit more info such as the build of ccleaner you are using and also which operating system you run.
Also which browser do you use? (must be closed when cleaning of course)
Is this something which has just started happening?
