Cookie Viewer
HI there,
Would it be possible to add a 'Cookie Viewer" option?
Reason: When I go to some sites that I am a member it pops a cookie on my PC, after I enter my username/password I get another cookie. Since I like keeping the cookies with my username/passwords so I don't need to re-enter them at each visit, I'd like to be able to view the cookies so I know which one contains my username/password and only save that one.
I also think it would be a nice option to be able to see what's in the cookies while the program is running.
Thanks!,
Oz
Hi Ozmoz, and welcome to the forum.
That's not a bad suggestion. I could use that myself, as it's often a case of keeping all cookies from a particular site, and by a tedious process of elimination, finding the relevant one.
Whether it could be easily implemented I don't know, but thanks for the suggestion.
Aren't cookies encrypted, and thus only decryptable by the relevant website/application?
WinPatrol can display cookies and they have readable stuff and numbers.
Thank you for the consideration :-)
I've opened many cookies in notepad, and amongst the encrypted data I usually find "readable" refferences to the login details I'm looking for. This also applies to flash cookies, "settings.sol" files.
IECookiesView v1.73 Cookies viewer-manager for Internet Explorer (zipfile 94 kB).
No installation. Portable.
In menu 'File' -> 'Installation Options' can be checked "Show a cookies button in Internet Explorer toolbar".
:rolleyes:
