Cookie Cleaning totally borked!
So.. a new version 7. Missing the primary cookie management functions that are the only reason I have paid for this now useless software.
How do I get my money back?
Are you going to fix this quickly? Or… how do I cancel this now useless software?
In custom clean press settings in the righthand pane.
in healthcheck run a scan then find settings in the right hand pane. sadly it isn’t as intuitive with cookies on computer and cookies to keep panes. You’ll need to manually type the address to keep
I am aware of this. I had dozens of cookie settings, and trying to start over without the ability to see the included and excluded cookies is not really a solve. I will possibly downgrade to v6 if this is not solved soon. They took away advertised functions that were fully paid for. The may result in a class action or consumer fraud suit. I’m not generally in favor of those because the recovery is small, but in this case if Piriform does not fix the problems, it’s fair game.
