Many times cookies that appear in the Options -> Cookies section are not identified when the Cleaner is run. If I only check "Cookies" in the Windows and Applications tabs and then run Analyze, no entries appear, although cookies are still listed in the Options section.
Bleachbit, however, when given the same instructions (find only cookies) finds the cookie files and deletes them.
