control panel
how do i remove the thing circled in red?
To hide:
Note: You must know the name of the controlpanelfile (I think it's BDEADMIN.CPL)
1:Open RegEdit
2:Find HKEY_CURRENT_USER\Control Panel\don't load
3:Rightclick on the main right windows
4:Select New->String
5:Name it the name of the cpl-file (BDEADMIN.CPL)
6:Done
To completely remove:
1:Search for BDEADMIN.CPL
2:If found, delete it.
3:Done
Hope it helps! :)
Heh, the Borland Database Engine... *don't* delete the CPL, just hide it as described.
:) ok... thanks DjLizard and USSR :)
USSR: how you know the name of that thing?
TweakUI > Control Panel.
i dont have that funny thing installed...
Really? Makes it nice and easy to fix many things.
A Google search, but as I said before I wasn't sure about the name.
dont really like to tweak my system... :)
oh... :D thanks a lot
I have never had a Windows PC without installing TweakUI. It's just one of those must have tools for Windows.
:) i dont know... maybe i should install it...
