Comment field
Hello. I can't see all the writing in the Comment field to see what file has overwritten. Is it possible to see all the writing?
In Advanced Mode the Info pane will show the full comment for each file.
It isn't a mode to pay, right?
No. If you are in Wizard mode, just click on the Switch to Advanced Mode box in the top right corner.
Thank you.
