comment défragmenter un répertoire complètement
Bonjour
avec la version V2 21 993 (gratuite ) j e ne retrouve plus comment défragmenter un répertoire complètement
sous Windows vista
merci pour votre réponse
My knowledge of the French language is (very) "limited". So, I'll reply in english. ("GOOGLE translate" provided a very neat translation).
- Once you've got a list of fragmented files, select/highlight one (fragmented) file from that directory, then "right-click" on that (highlighted) file. Then a number of additional options emerge. Select "Highlight Folder" and choose one of the directories that show up. Then check one of the highlighted files. It will then highlight all defragmented files in that folder. Then hit "Defrag" to defragment those files.
