Command Software registry entries keep reappearing after cleaning.
I deleted all the files from some program called "Command Software." I run the registry cleaner and "fix" but the next time I run it I get the same errors. Below is the info CCleaner gives me. Does anyone have any idea how to get rid of these entries? Much thanks for any info on what the heck is going on. :)
Missing Shared DLL C:\Program Files\Common Files\Command Software\3rdeapi.dll HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Program Files\Common Files\Command Software\odapi.dll HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Program Files\Common Files\Command Software\css-dvp.cat HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Program Files\Common Files\Command Software\dvpnt.inf HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Program Files\Common Files\Command Software\dvpmgr.exe HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\WINDOWS\system32\msvcr70.dll HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Program Files\Common Files\Command Software\defvn.dll HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Program Files\Common Files\Command Software\css3rdem.dll HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Program Files\Common Files\Command Software\fixdsknt.exe HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Program Files\Common Files\Command Software\FIXDISK.EXE HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Program Files\Common Files\Command Software\f-prot.exe HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Program Files\Common Files\Command Software\english.tx2 HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Program Files\Common Files\Command Software\csscan32.dll HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Program Files\Common Files\Command Software\css3rde.dll HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Program Files\Common Files\Command Software\avevent.exe HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
please confirm, you delete the files? you didn't uninstall the software?
if this is the case you may have left behind system files form said program. If so you need to reinstall command software (whatever that may be) and uninstall it. Then the entries should go. if not please continue to post :)
(and welcome)
