Command Line Switches/Options
Where can the list of Command Line Options be found? The updated version forgets or ignores settings regarding automatic startup. An answer to another query on this forum showed how to start CCleaner automtically, but it does not show how to prevent it from starting automatically.
For example, if the setting is selected to NOT start automatically, any update to the program resets to Piriform's automatic default rather than to the user's different choice.
