Combo fix
Notice on the bleeping computer forums
http://download.bleepingcomputer.com/sUBs/ComboFix.html
Seems they are working fast on it, according to there facebook page there is a public beta available:
http://www.facebook.com/pages/BleepingComp...23401752?v=wall
(posted yesterday)
BleepingComputer Beta of Combofix is available for public testing.
The bug that caused it to be pulled has been fixed and you can now use the following beta.
If there are any issues that arise please post about them at the BC forums.
The beta is expected to run for a couple of days, and this version of CF will expire in 4 days.
You can get the beta here:
http://download.bleepingcomputer.com/sUBs/Beta/KittyFix.exe
Remember this is a BETA, so you may not want to use it on your main pc!
You do NOT want to use ComboFix by yourself, unless you're advised by a trained malware fighter.
