Hi there
check out Sven Hoffmann's ClearProg. I'm using both programms - and I still have got a clean PC, because ClearProgs delete's much better the user-temp as CCleaner.
Maybe you can combine CCleaner and ClearProg in ONE program?
ClearProg: => http://www.clearprog.de
Download: => http://www.clearprog.de/downloads.php?lang=en
I don't think so, and I'm sure you don't really believe they can be combined either
If you want to unlock CCleaner's ability to deal with Temp dir files more rapidly you can disable the 48 hour rule setting in 'Options->Advanced'.
I suppose when a registry app says you have 300 problems its better then ccleaner also
/sigh
