Colone not resizable
Hi I board a slight problem namely tab (List of fragmented files)
it is impossible to redimentioner the columns, Filename, Fragments, Location, etc ...)
Sorry for my broken English ;).
Ps: I grieve the wrong forum to post if a moderator can move this message in the Defraggler it would nice
Wrong place at the forums.
Should be moved to Defraggler Bug Reporting.
I couldn't recreate this, I can expand the columns just fine.
Which Defraggler version are you using?
I use the v.2.11.560 (64 bits) and the os: Windows 7 64 bits Family Edition
I can reproduce this, but only before analysing with the file list empty.
The columns are also locked during the defrag process, which you appear to be doing in your screenshot.
If you need to alter column widths, do it after an analyse and before defragging.
EDIT: Welcome to the forum by the way.
ok thank you for this information.
Yes i have launching the defragmentation for disk 2 TB it's estimated more than one day :)
I've just reworded my post slightly with this ...
My fingers didn't type what my brain was thinking. :)
