Closure on cleaning
I have used cccleaner for many years without any problems, but recently following updateing, the system closes down immediately following ‘ the command clean ‘.
Having checked various help sites, one which recommended that a complete uninstall and reinstall was necessary.
I’m fairy uptodate on my knowledge ( even at my age of 81 ) - I followed the instructions and installed an uptodate version ( 5.42.6495 (64 bit ) ) to find that the same problem exists. I can clean the registry ok, but on the ‘ cleaner ‘ side , after the run cleaner tile activated followed by do you wish to continue -whoops all goes to a blank screen.
can anyone assist please.
Thanks
This seems to be a flaw in the latest (5.42) ccleaner. others have reported similar crashes when running file cleaning
