I just installed Avant Browser after seeing how fast IE is on my machine (Avant uses the IE layout engine, Trident). Can someone tell me how to turn off the annoying "click" sound every time I click the mouse in IE? I'm referring to the sound made every time you click a link or a button in the browser. I've dug through all the options, but can't find anything. Thanks!
Windows XP:
1. Go to: Control Panel->Sound, Speech, Audio Devices->Sound and Audio Devices
2. Click the tab: Sounds
It "may" be this one:
Under Windows->Start Navigation
The wav file in question is: Windows Navigation Start.wav
Indeed it's annoying as hell, which is why I turn off all those sounds.
That did it! Thank you very much! Much better now.
Windows XP:1. Go to: Control Panel->Sound, Speech, Audio Devices->Sound and Audio Devices
What do you check or uncheck in there? There doesn't appear to be any thing to check in the sounds tab.
