Click ALL
Shouldnt CCleaner by now have a click all button on the bottom so i do not have to go through and click all of it? just a suggestion, but that would be nice
Which section of ccleaner are you meaning?
Are you seriously meaning click all of the checkboxes in ccleaner advanced ?
I'm glad hazelnut posed the question, that I too had. in general a click all is a bad idea, imho this is doubly so for ccleaner where a user should have to be given cause to look at each entry and evaluate each cleaning individually.
Each section already has a right click menu.
For example, right click on Internet Explorer, Windows Explorer, etc....
You are given five choices.
1) Check all
2) Uncheck all
3) Analyze
4) Clean
5) Restore to default state
This works for the Windows and Applications tabs as well.
If you hover your mouse over the tab name, you can change all sections within the tab at once.
If check all is used, you should read each warning as they pop up.
I would use these options with caution!
The Registry Cleaner section doesn't have the analyze or clean options.
Would be nice, though.
Scan for issues is very similar to Analyze, is it not?
Or did u have something else in mind?
