Clears IE history when not checked
Not sure if this is a bug or me, but recently, CCleaner is clearing my IE history (which I don't want) even though it is unchecked in the options. Since I'm one of those who forget where I've been sometimes ;), I really do want my history back a few weeks, which is how I have my preferences set in IE 11. But lately CC is leaving me without a history (until I run CC, the history displays fine). How can I make sure it leaves my history alone? Again, the option under Windows/Internet Explorer/History is unchecked.
have you tried unticking all IE options in CC and seeing if that still clears your history - it shouldn't.
then tick them back on, one by one, till the problem reoccurs, and you'll have the culprit.<img alt=":)" data-emoticon="" height="20" src="<fileStore.core_Emoticons>/emoticons/default_smile.png" srcset="<fileStore.core_Emoticons>/emoticons/smile@2x.png 2x" title=":)" width="20"></p>
what are your CC and Windows versions?
Nancy Drew, girl sleuth on the case :); I think I found the culprit, sorta .First, to answer questions: Running CC 5.37.92.6309 which I think is the latest, under Win 8.1 and IE 11. Unticking all IE options in CC didn't help---history still cleared completely. However, I did notice when doing an analysis that there was an "Internet Explorer More" which was from CCEnchancer, but unlike most of the CCEnhancer additions, that one isn't even listed under Applications with choices, but as a single choice under Internet, so no way to tell that not to clear history (which shouldn't even be related since that is covered by normal CC and unchecked). So I unchecked Internet Explorer More, went to a few site to get a history, and ran CC again and it didn't delete the history! So the culprit is Internet Explorer More and the fact that it doesn't allow any granularity. I'd love to have it do everything else to wipe IE, but not at the cost of my history.
The oddest thing is, I haven't updated CCEnhancer in ages, but update regular CC every time an update is offered, and this unwanted behavior only started after a few updates ago. Making me assume it was CC.
good investigative skills their Sherlock.
but sadly that brings us to a brick wall as we don't support that, or any, enhancement of CC.
Absolutely understand that, but thought it was relevant since the issue came up not with any update to CCenchancer or the winapp2.ini, but with an update (not sure which one) to CCleaner. Anyway, guess I'll have to leave that unchecked altogether in order to retain my history.
