Hi, I think there's a problem with cleaning moved Temp directory. Usually it's located at "c:\windows\temp" (talking about XP SP2 now) but when moved let's say to "t:\temp" (T is a FAT32 partition dedicated for temporary mess) by changing corresponding path in system variables, CCleaner doesn't seem to clean it.
Also I've been encoutering some reported/cleaned files ratio difference. Sometimes CCleaner reports 10 files for some directory but then says only 3 of them were deleted. What's the problem?
Please everyone ignore my question about TEMP not working - WORKS FINE !! The error was exactly between chair and keyboard :-D I had the option "Only delete files older than 24 hours" ticked that's why CCleaner didn't find anything.
For Alan_B: Thanks for the answer and no, my C partition is the slow NTFS, only T is the quick and unreliable FAT32.
