ds7060
1
Hi,
Each time I start to clean the PC on Windows tab, Windows shutdown.
Working perfectly if launched auto at windows startup.
Any idea?
Tku
Here's two things for you to check which can cause this:
1. Go into Options > Advanced and make sure 'Shutdown after cleaning' is unticked.
2. Right-click your CCleaner shortcuts (such as the one on the desktop, etc.,) and make sure the 'Target' field does NOT have /shutdown listed in it.
For example:
* Runs CCleaner normally: "C:\path to ccleaner\ccleaner.exe"
* CCleaner will automatically clean and shutdown the computer: "C:\path to ccleaner\ccleaner.exe" /auto /shutdown
More info available in the CCleaner help documentation:
