I've looked through the forums here and couldn't find anything on this. A friend is using CC Cleaner but has two hard drives. CC Cleaner analyzes and cleans the C: drive by default. Is there a way to do this for his other drive (which is strictly for storage) also? He tried going the custom folders route, only to realize that option was for deleting everything within the folders rather than cleaning. Thanks.
Never tried it, but under options there is "custom folders" which gives you the option to add the folders you want to clean.Disregard. read your post again. I was not aware it would delete all contents.
cjacks9 CCleaner only cleaner out temp folders and rubbish that apps create if as you say your friend only uses the second drive for storage i.e. there are no programs on it then there would be nothing for CCleaner to clean.
