On my system (Windows XP Home SP2) the folders I set in the Include list are always ignored both in the analysis and the cleaning process. I just tried with the latest version 2.05 but the behavior is always the same the custom folders I list are not cleaned. Any suggestion? Thanks
Silly questions first: you have Custom Files and Folders ticked under Cleaner/Windows/Advanced? There are some files in your custom folder? (The custom folder is not deleted, the contents are.) Can you delete your existing entry in the Include list and drag/drop the folder in (to make sure the path/name is OK)?
My custom folders/files were missing after I installed 2.05 today. First time that's ever happened to me. I added them back and they're staying put.
Augeas thanks, I did not note I had to tick Custom Files and Folders under Cleaner/Windows/Advanced. Problem solved.
It's always good to hear of a happy resolution - rgds.
