Cleaning not progressing
I downloaded cleaner today and the cleaning would not progress beyond 30%. It was stuck on "Taskbar Jump Lists". I then cancelled the cleaning and unchecked Taskbar Jump Lists and restarted the cleaning. It is now stuck at 34% on "Temporary Files".
Any suggestions?
I've had similar results with the past few CCleaner updates. I found that I had to reboot the PC and then CCleaner would complete normally.
Have you rebooted since installing CCleaner?
