Cleaning IE8's InPrivate Filtering data
Hello,
One of Internet Explorer 8's utilities is called "InPrivate Filtering".
It analyses websites for "Third Party Content", blocking such content when it detects that this could be used for tracking the user. This is to prevent such tracking data being used for targeted advertising.
While doing this, IE retains information about the websites you visit.
(In IE you can remove the InPrivate Filtering data, by doing:
?Internet Options? dialog box: ?General? tab:
Click: ?Delete??/
?Delete Browsing History? dialog box:
CHeck: ?InPrivate Filtering data?/OK.)
Does Ccleaner have any option for removing IE8's "InPrivate Filtering" data, so that this can be included in a Ccleaner general cleanse, and also so that the user can take advantage of Ccleaner's secure deletion options?
I hope to receive an answer to this query.
Regards,
Robert333
