Please help download the old version of ccleaner (before Avast acquired Piriform Ltd).
I do not want my personal data to be stolen, despite the fact that it is allowed by American law (after September 11).
but the most important thing! The program stopped cleaning hidden downloads after the first Internet connection.
You can get old freeware versions on FileHippo here:
https://filehippo.com/download_ccleaner/history/
A pre-Avast era influence version might be v5.28 if I'm remembering correctly. Do note that if you use Windows 10 the operating system won't let you use that version since it's now too old - but even if you do find an old version that works it will likely just update itself rather you want it to or not.
