Cleaning Flash Information
While using the Adobe Flash control panel at:
http://www.macromedia.com/support/document..._manager07.html
I noticed that even though I had just run CCleaner, the Flash history still showed each web site I had visited that used Flash. Can this be cleaned?
http://forum.piriform.com/index.php?showto…65&hl=Flash
Hi
local Shared Object sometimes referred to as "Flash cookies"
http://kb2.adobe.com/cps/161/tn_16194.html
http://www.adobe.com/products/flashplayer/articles/lso/
to delete
http://kb2.adobe.com/cps/526/52697ee8.html
stop saving
http://www.macromedia.com/support/documentation/en/flashplayer/help/settings_manager03.html
under ccleaner / options / include
i have added
C:\Documents and Settings\u1\Application Data\Macromedia\Flash Player\#SharedObjects\
note u1 is my profile you will need your profile.
vietnamrum
