'Not sure what the comparison chart showing the capabilities of CCleaner Free, Professional means.
For example: CCleaner Free does not have a check in the "Complete Cleaning" box.
What does the Free version clean: anything?
According to the developers "complete cleaning" refers to the ability to clean multiple users at the same time. The cleaning routines between the two versions are equal though
Thank you for the information.
