Cleaning Cookies I want to keep
CCleaner v2.35.1223
the cleaner is cleaning out cookies I would prefer to keep.
The cookies are NOT listed in either pane when I go to Options > Cookies
If I uncheck either or both Temporary Internet Files and Cookies they are still being deleted
I have created NO custom inclusions for cleaning
When I look at the internet cache files I can see the cookies in question before running the cleaner
C:\Users\[username]\AppData\Local\Microsoft\Windows\Temporary Internet Files
here is some system info
***OS Version Information***
-Major Version: 6
-Minor Version: 0
-Build Number: 6002
-Platform: Windows Vista
-CSDVersion: Service Pack 2
-Bit Width:32
SlimBrowser Version: 5.00.092
IE Version: 8.0.6001.18928
IE8 Mode: 0
SlimBrowser Interface Language:English US
Default OS Language:English US
Total Memory:2046MB
my problem is that none of the cookies seem to be deleted since the most recent updates.
i'm running IE8 on windows xp home edition service pack 3, along with firefox, and tho all the cookies i so carefully saved are still there, so are all the cookies i wanted deleted...i do check both before and after running the cleaner. what's up with that!
Your problem is the absolute opposite to the subject of this thread.
There is no feasible solution that would work for both of you.
You need to start a separate thread for your problem,
and it would help if you identified WHICH browser was responsible for WHICH cookies.
You did not need to list all cookies
Also the version of Firefox might help.
Alan
-snip-
-snip-
Alan
Rolling back through previous versions until the problem goes away could feasibly work for both of us :P
However, I do agree he should have started his own Topic. It is different enough from mine to be considered a "hijack" of the thread on some forums.
New topic posted re: cookies not being deleted.
though I do agree that previous versions of CCleaner did not have this problem.
I disagree.
You have reported that earlier versions of CCleaner did not have this problem.
But I never saw, and still cannot see, any such report by oftentired.
Never mind, at least you are now on a separate topic.
Regards
Alan
