When running WFS the program always ends with error message "Cleaning Cancelled - This cleaning is incomplete"
The cancellation is done by the program itself, not the operator.
The last bit of the de-bug log is
[15:04:41::357][iNFO ] OnRuleStarted | 3025 | | MS Wordpad
[15:04:41::357][iNFO ] OnRuleFinished | 3025 | | MS Wordpad
[15:04:41::357][iNFO ] OnRuleStarted | 3025 | | RegEdit
[15:04:41::357][iNFO ] OnRuleFinished | 3025 | | RegEdit
[15:04:41::357][iNFO ] OnRuleStarted | 3004 | 3132 | Wipe Free Space
[15:48:49::501][DEBUG] Cleaner - Initializing Stop request...
[15:49:20::206][iNFO ] OnRuleFinished | 3004 | 3132 | Wipe Free Space
[15:49:20::206][iNFO ] OnCancelled
[15:49:20::206][iNFO ] Leaving Cleaning
[15:49:20::206][DEBUG] Cleaner - Finished Stop request
[15:49:20::237][DEBUG] CLEANING CANCELLED - (2680.814 secs)
[15:49:20::237][DEBUG] This cleaning is incomplete
[15:49:20::237][DEBUG] 3.50 MB removed.
[15:50:21::610][iNFO ] Closing application...
[15:50:21::623][iNFO ] Finished closing application
[15:50:21::623][iNFO ] Application Ended
This problem occurs when using CCleaner64 v4.02.4115 on a 250GB partition. The program seemed to work normally several weeks ago so some unknown change must have occurred since then.
Many thanks for any advice forthcoming.
