Priority:
Very Low
Synopsis:
IE/Firefox's caches are not cleaned when moved out of the default user profile
Description:
I've moved my Cache off my C: drive (as it is an SSD, moving the profile once caused me to loose the hard link to D: after a power failure and I had to rebuild the system). I've moved all caches and other dynamic files to D: when able so I've moved both IE and Firefox's cache to d: but CCleaner doesn't look at the settings and seems to only clean the default location.
Work Around:
Set CCleaner to delete the directories with the cache files automatically when run.
Preferred behavior:
CCleaner automatically determines cache location and cleans without user intervention.
