When you open the task manager craig there is a help option on the top line which, if you click on, you can choose the help topics. There's quite a lot of task manager info in that, worth a read anyway.
Hi Hazelnut
Thanks for the tip, I have to admit that I'm a bit lazy when it comes to reading windows help topics I tend to just brush over them.
Cleaning the Customize Notifications icons is much easier using a script such as # 53. Remove Past Items From Notification Area, you have to scroll down to it. The script is 100% clean, it automatically ends the Explorer.exe task and automatically restarts it. I've been using it for a long time now. You do need to actually restart Windows after using it though, otherwise the Customize Notifications icons settings won't be saved.
