Cleaner Resetting order of IE Favorites/Bookmarks? How do I disable that?
Just Downloaded and started using Crap Cleaner...and I think it is awesome! I can tell a difference in my PC. Seems to be working better than Systemworks WinDoctor....
BUT
I have have a TON of favorite /bookmarks and have them in my own order with sites that I frequent at the top.
After running Cleaner, I am noticing that it re-sorts my favs list alpha-numerically.
How can I disable this?
Help is greatly appriciated!
--Yankee
Until the problem is fixed about the only suggestion I'd have would be to:
1. Disable all the IE cleaning items in CCleaner.
2. Then enable the IE cleaning items in CCleaner one at a time, run CCleaner, then run IE to see what has happened. Do this until you find out what exactly is causing it, which would of course weed out which cleaning part is causing the problem.
Also make sure you're not running CCleaner with IE open and running!
This is getting to be a real pain in the .... Any idea when it will be fixed?
If you have "Menu order cache" in Advanced selected, try unselecting it and see if that helps.
It might be fixed quicker if you can make time to do as Andavari suggested and let us know exactly which of the IE cleaning options is causing the problem you are seeing.
It's been doing this for the last 3 versions at least. Uncheck other MRU's
I can't make CCleaner do this.
I have checked every single thing except the advanced section and used it with IE open and closed. (I've tried it with all 3 of my xp machines)
I wonder if its has something to do with the other software on your machine. (although I don't know how it could..)
