Cleaner is deleting my spam blocks
When I run CC Cleaner I find that the spam emails that I block as spam to my "Spamfighter and/or Bit Defender show up again after I run the Cleaner. I think I have something checked that I shouldn't, but I don't know which check I should remove. Please help.
Are you using a modified winapp.ini or winapp2.ini ?
Is XP(sp3)or Outlook Express 6 what you're looking for?
