Cleaner and macromedia flash panel settings
XP Pro SP3 CCleaner 2.12.660 version
I recently learned how to use the macromedia flash panel settings. http://www.macromedia.com/support/document...r07.html#117717
Using FireFox 2.0.17 as my browser, I set it up for best security settings. I then used CCleaner and found it removed the file on my computer where the settings are stored. Is there something I have set wrong in CCleaner?
Under windows tab I have everything checked except there are no checks in advanced section.
Thanks
Take Care
Celeste
PS Sorry I posted this in wrong area and can't find out how to delete the post so I will leave it here. I meant to post in open discussion area. I don't think this is a bug as much as I as the operator of CCleaner may be doing something wrong.
Try under the CCleaner application tab, unticking adobe flash player (macromedia)
Yeppers that is it. Thank you
Take Care
Celeste
